I have a code that shows the Evaporative emission system purge control valve circuit is shorted, what would be some common fixes. Code # PO445
Apr 6, 2010 at 7:09 AM
✓Experienced Mechanic
Check the wiring at the purge valve. Disconnect the plug and check for corrosion or other problems (shorted wire or damaged pins in the plug).
Let me know what you find.
Apr 6, 2010 at 3:23 PM
MIKE DIZMANG
MEMBER
Hello Joe,well I checked the all the conections and everything looks good. I found nothing wrong. I did find a lose gas cap,would this give me a false reading?
