Chances are there is a problem with the actuator on the transfer case. What I need you to do is check to see if it is receiving power when the button is pushed. If it is, then remove the actuator and have it checked.
Let me know if this answers your questions or if you have others.
Dec 9, 2009 at 8:55 AM
