2006 Ford Explorer Warning light
2006 FORD EXPLORER
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
DGIBSO
A red battery pops up and underneath it says, "Check Charging System". I replaced the battery and am still having the pop up. Everything else in the vehicle operates properly.
Jan 19, 2009 at 9:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Alternator is properly going bad. You can have it tested for free at most local part stores such as Advance Auto Parts or AutoZone. You can have it tested both on or off of the vehicle.
Thanks for using 2CarPros.com!
Jan 19, 2009 at 10:02 PM
