2006 Ford Explorer Radiater
RSELLERS
  • 6 POSTS
Engine Cooling problem
2006 Ford Explorer 6 cyl Two Wheel Drive Automatic
how hard is it to replace the radiater?any special tool to remove transmisson lines from radiater?
Mar 5, 2010 at 6:45 AM
  • 110,248 POSTS
The worst part is trying to access the bolts that hold everything in place. Remove the shroud first, then you can get to the radiator. As far as the trans lines, nothing special is needed.
Mar 5, 2010 at 3:57 PM
