2006 Ford Explorer Loud Noise underhood
JAKESC7
  • 2006 FORD EXPLORER
Noises problem
2006 Ford Explorer 6 cyl Two Wheel Drive Automatic
When I'm driving for a while and then slow or come to a stop, and then reaccelerate again, sometimes I hear this loud, exhaust-fan like, revving sound coming from the front of the car. Its the same sound my car makes when I first turn on my a/c. But in the situation I described my a/c is not on. Any ideas on what may be causing this? Cooling fan, coolong system, some sort of sensor. Please help
Monday, September 20th, 2010 AT 4:29 PM
  • 109,885 POSTS
It sounds like the fan clutch is engaging and you are hearing it. They are loud when the fully engage. Does it sound like a large fan turning on?
Monday, September 20th, 2010 AT 10:44 PM
JAKESC7
  • 5 POSTS
Yeah thats exactly what it sounds like. Why would that fan be engaging when my a/c is off? It seems I have plenty of coolant, so I dont think I'm overheating.
Could it be a bad sensor or thermostat?
Tuesday, September 21st, 2010 AT 11:47 AM
  • 109,885 POSTS
The clutch fan functions based on a thermostatic spring that expands and contracts based on temp. If the under hood temp reaches a certain temp, it will full engage the fan and that is what it sounds like. If you open the hood, you will see the fan turns all the time when the engine is running. It just speeds up when the temp increases making that noise.
Wednesday, September 22nd, 2010 AT 12:24 AM
JAKESC7
  • 5 POSTS
Ok, when you say the temp. "Under the hood", are you refering to the actual engine temp. Or rather that b/c it might be a hot day outside the temp. Right underneath the hood is really high?
If its the radiator fan clutch turning on louder/faster I would have figured that its trying to increase cool air flow to the radiator b/c the engine is getting too hot.
The fact that the a/c is off, and that fan is spinning so fast I'm thinking 1 of 3 thiings. 1. The thermostat is giving an incorrect reading 2. The engine really is getting that hot (maybe b/c of low/leaking coolant), or 3. Its just normal operation of the vehicle and shouldn't be all that worried about it
Sorry this is so wordy. I really appreciate all your help.
Thanks
Wednesday, September 22nd, 2010 AT 9:07 AM
  • 109,885 POSTS
It is under hood temp. Also, it sounds like it is working correctly. If I remember correctly, there is an electric fan that comes on with the AC which would help keep the temp down under the hood. Thus, the fan wouldn't need to fully engage.
Feel free to ask any questions you may have.
Wednesday, September 22nd, 2010 AT 11:29 PM
