2006 Ford Explorer engine misfire
46,000 MILES • 6 CYL • 4WD • AUTOMATIC
KANDJFRISCH
Check engine light came on, and had the code read. It was a number 5 misfire. It runs bad a an idile and when I put a load on it, it runs wrose and has a surdge. when driving, it makes a back pressure sound. I have replaced the spark plugs, wire, coil, fuel filter, and fuel injector. When pulling the spark plug wires, when running, a change in engine on all wires except 5 & 6. I am now lost and don't know what to do next. can you help?
Dec 16, 2008 at 11:57 AM
BMRFIXIT
  • 19,053 POSTS
Have you done a compression test
I would
when you pull the wire of the spark do u have spark on it
checked the injector pulse
Dec 21, 2020 at 3:17 AM
KANDJFRISCH
I have done a compression test and all range between 185-195. When I did pull the wires, all wire do have a spark. How do you check the injector pulse?
BMRFIXIT
  • 19,053 POSTS
Locate the injector and pull it electric connector and check use a small light bulb (194) or a noid light place in the plug and it should flash on off when engine running
https://images.2carpros.com/forum/automotive_pictures/99387_8_21_2007_13_3_11_1.jpg
