ac drain location?
EDWEATHER
Where is the ac evaporator core drain located, so I can unclog it? Thanks.
Oct 10, 2010 at 3:01 PM
The drain is located on the driver side of the HVAC housing. Please take a look at the image below and see if you can locate it.
More then likely you will have an extension line coming off of this port which will be a rubber line. You may have to remove this in order to really clean it out.
Please review this material and let us know if you have other questions. Thanks
Jul 13, 2021 at 4:20 AM
