2005 Ford Explorer sway bar bushings
2005 FORD EXPLORER
53,600 MILES • 6 CYL • 4WD • AUTOMATIC
GP2CARPROS
I brought my 05 Explorer in for a noise it made in the front end when turning hard to the right, for example pulling into a tight parking space. I was told the sway bar bushings are bad. How hard are these to replace and what should I use to condition the new ones once they are replaced; Ford tells me they spray something on them to keep them from drying.
The same side has a missing clamp on the axle boot and the boot has ripped as a result, Is this a difficult repair or can it be done in my driveway?
If you have any step by step links or other instructions please provide.
Oct 31, 2008 at 4:44 AM
JAMES W.
  • 2,394 POSTS
If you have an outboard torn axle boot I'm willing to bet that joint is bad. The sharper you turn, the more noise they will make.
Oct 31, 2008 at 11:00 AM
GP2CARPROS
I'm not sure what size "donation" provokes a good answer but that was the biggest waste of $20 I think I've ever seen. Please read the question next time and either answer it with some useful information or give me back my $20
Nov 2, 2008 at 11:41 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect the noise is from the axle
and since the boot is torn that would put it on the 1st things to do .
as if u can do it in the drive way .
its all depend on your ability and tools
I will include the steps and let you make your decision on that
if you need more let me know
FRONT DRIVE HALFSHAFTS -2005 Ford Explorer
Removal and Installation
CAUTION: Do not loosen the front axle wheel end nut until after the wheel and tire assembly are removed from the vehicle. Wheel bearing damage will occur if the wheel bearing is unloaded with the weight of the vehicle applied.
1.With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to JACKING AND LIFTING .
2.Remove the front wheel and tire assembly
3.Remove and discard the front axle wheel end nut.
To install, tighten to 250 Nm (184 lb-ft).
CAUTION: To prevent damage to the brake hose, do not allow the disc brake caliper to hang suspended from the hose.
4.Remove the 2 disc brake caliper guide pin bolts and position the disc brake caliper aside.
To install, tighten to 33 Nm (24 lb-ft).
Using mechanic's wire, position the disc brake caliper aside.
CAUTION: Do not use a hammer to separate the outboard CV joint from the hub. Damage to the threads and internal CV joint components can result.
5.Using the special tool, press the outboard CV joint until it is loose in the hub.
6.Remove the tie-rod nut.
To install, tighten to 70 Nm (52 lb-ft). 7.Using the special tool, separate the tie-rod from the knuckle.
8.Remove the stabilizer bar link nut.
To install, tighten to 25 Nm (18 lb-ft).
9.Remove the upper ball joint nut.
To install, tighten to 69 Nm (51 lb-ft).
CAUTION: Do not allow the knuckle to hang freely. It is possible to overextend and internally separate each inner CV joint from its housing.
10.Using the special tool, disconnect the upper ball joint from the knuckle.
CAUTION: Do not damage the axle shaft oil seal or the machined sealing surface on the inboard CV joint housing.
NOTE: A circlip retains the inboard CV joint housing to the differential side gear in the axle.
11.Using the special tool, disengage the LH CV joint housing from the side gear.
12.Remove the LH halfshaft.
CAUTION: Do not damage the axle shaft oil seal, the machined sealing surface on the inboard CV joint housing or the axle shaft splines.
CAUTION:I nstall a new retainer circlip on the outboard spline end of the axle shaft before reseating the axle shaft in the differential side gear.
13.Pull the RH halfshaft and the axle shaft away from the axle tube, and separate the inboard CV joint housing from the axle shaft.
14.Remove the RH halfshaft.
CAUTION: Install and tighten the new axle wheel end nut to specification in a continuous rotation. Stopping the rotation during installation will cause the nylon lock to seat incorrectly. This will cause incorrect torque readings while tightening the axle wheel end nut and lead to bearing failure. Always install a new
axle wheel end nut after loosening or when not tightened to specifications in a continuous rotation.
CAUTION: Install a new circlip every time the halfshaft is removed.
NOTE: Start one end of the circlip in the groove and work the circlip over the halfshaft and into the groove to prevent the circlip from overexpanding.
15.To install, reverse the removal procedure.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_23.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic3_10.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic4_4.jpg
Nov 5, 2008 at 10:53 PM
GP2CARPROS
Thanks for that awesome answer!!!!! After seeing the first reply I thought thats all I would get so sorry if I jumped down your throat (so to speak).
After further examination I found no tears in the boot leading me to believe the dealership was trying to make some extra money for themselves by cutting of my boot clamp or they broke the clamp during their diagnosis and thought they would get a full repair charge out of me.
The sway bar bushing is now my biggest priority it looks like the new part has a split which means I don't have to remove the stabilizer bar link nut to uninstall/install the bushing?
Nov 6, 2008 at 7:14 AM
BMRFIXIT
  • 19,053 POSTS
To do the bushings no need to remove the links
and that should be a lot easier to do
let me know if need any more info.
Nov 6, 2008 at 7:46 AM
