2005 Ford Explorer problems that don't add up
76,000 MILES • 6 CYL • 4WD • AUTOMATIC
DNAMILLER
When I tried to start the car today, it didn't so I thought the battery was going. I brought it to a repiar shop and indeed I needed a new battery. When I was switching out the new battery, as soon as I connected the positive cable, sparks flew out the otherside of the engine and my car horn started going off! I switched the batterys back because I didn't want anything to get ruined and jumped the bad battery again. After a few minutes, everything died in my car including the headlights, radio, basically everything electrical, but what I don't get is...my transmission would't switch gears, It felt like i was in neutral the whole time and it seemed the engine wasn't getting enough gas to push it. I bascially had to coast the whole way home. Please help me!
Apr 9, 2009 at 3:53 PM
  • 31,937 POSTS
Hi there,
I can only think that then new battery was attached back wards, and you may have damaged some electrical components, i would start with a scan to see if there are any set fault codes, start here.
mark (mhpautos)
Apr 9, 2009 at 4:17 PM
