2005 Ford Explorer limp home mode
59,489 MILES • 6 CYL • FWD • AUTOMATIC
PARKINSONKIMBERLY
How can I fix my car Is their a switch to push I don't have the money to take it to the dealer I just put new tires on it and it says tire sensor failed
Jan 19, 2010 at 8:59 PM
  • 110,248 POSTS
If you just had the work done, have the shop that replaced the tires recheck their work. If it said low pressure, it can be reset, but it is telling you that a sensor is bad. It may have been damaged when the tires were installed.
Jan 20, 2010 at 2:46 AM
