Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Fuel System
Fuel Pump
Fuse
2005 Ford Explorer FUEL PUMP
2005 FORD EXPLORER
62,000 MILES • 6 CYL • 4WD • AUTOMATIC
MALCOLMB
MEMBER
1 POST
FUEL PUMP FUSE KEEP BLOWING , I'VE CHANGED OUT FUEL PUMP AND ASSEMBLY , BUT THE FUSE KEEP BLOWING
Jan 31, 2009 at 4:09 AM
BLUELIGHTNIN6
Experienced Mechanic
Inspect wiring to fuel pump for any shorts. If OK, suspect faulty starter. Starter solenoid is on same circuit.
Thanks for using 2CarPros.com!
Jan 31, 2009 at 4:14 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
