Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Not Cranking Over
2005 Ford Explorer engine won't turn over
2005 FORD EXPLORER
37,000 MILES • V8 • 4WD • AUTOMATIC
DRMMCGOWAN
MEMBER
1 POST
Battery appears to be fine, all lights working. Turn the key and get nothing not even a clicking sound
Jan 11, 2010 at 9:56 AM
Experienced Mechanic
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Jan 11, 2010 at 10:25 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
