Coolant temperature sensor?
96,500 MILES • 4 CYL • 4WD • AUTOMATIC
KIM0074
I need to find and replace coolant temparture sensor , how do I find and what type of tools do I need to replace
Mar 17, 2009 at 1:31 AM
SQM
  • 6,383 POSTS
The coolant temperature sensor is located on top of the engine, just behind the thermostat housing.
It can be using basic hand tools.
Remember to only work on the cooling system when the engine is cool.
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
https://youtu.be/g4wRRxgjp94
I have attached the replacement procedure for your reference.
Aug 2, 2021 at 7:57 AM
