2005 Ford Explorer bearings
103,000 MILES • 6 CYL • 4WD • AUTOMATIC
RED_NECK_GEORGE
i have the driver side hub assy and i need to know how to be able to get the bearing out of the hub and replace the bearing bu i went to try and press it out with my hydro press it did not move and i can not find nothing on the comp to help me out a diagram or any thing and i was told i need to buy the hole hub assy by napa and ford and a couple others told e no i do not so do you all have any advice for me i really need it [img:fcd90879c1]http://www.2carpros.com/forum/automotive_pictures/525797_georges_pics_005_1.jpg[/img:fcd90879c1]
May 9, 2010 at 1:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the wheel bearing and hub are an assembly, if the bearing is bad then the assembly must be replaced as a whole only.
May 9, 2010 at 1:12 PM
