2005 Ford Explorer Air Control
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
MATU
My 05 Ford Explorer's heater (or AC) will only blow throw the dash and defrost. It will not change with the control knob to floor, mix floor dash etc. I looked for a vacuum leak and couldn't find one (not saying it's not there, just couldn't find one). What is the cause?
Feb 27, 2010 at 4:09 AM
  • 110,248 POSTS
Chances are it is a vacuum leak. If you look for it with the engine running, you may hear a hissing sound. Also, check under the hood for leaks and make sure the linkage is attached.
Feb 28, 2010 at 11:54 PM
