2005 Ford Explorer Air blows out of the floor and window ve
2005 FORD EXPLORER
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVLISON
The AC blows out of the floor and window vents but does not come out of the front vents. The air blows cold but in the wrong locations so the AC is relatively ineffective. What could be wrong?
Jun 8, 2010 at 2:16 PM
  • 110,244 POSTS
You are looking for a vacuum leak. The vents are actuated by vacuum. If there is a leak, this is what happens. Check for leaks under the dash and the under the hood. If you are lucky, start the engine and you may hear a hissing sound from the leak.
Jun 8, 2010 at 2:40 PM
