2005 Ford Explorer A/C not working
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
MICKER
The A/C on my 2005 Explorer stopped working. I have checked the fuses and the relay and they are all good. When I turn on the A/C it doesn't appear to even come on, so I don't think it's just low on refrigerant. Any suggestion I can try before taking it to the shop.
Thanks
May 24, 2008 at 12:43 AM
  • 31,937 POSTS
Hi there,
You may very well be down on refrigerant. If the system pressure is to low, the low pressure cut out switch will activate and isolate the clutch circuit. Have the system pressures tested first.
Mark (mhpautos)
May 24, 2008 at 12:48 AM
