2005 Ford Explorer A/C cool but not cold
SEXPISTOL1
  • 2005 FORD EXPLORER
Air Conditioning problem
2005 Ford Explorer 6 cyl Two Wheel Drive Automatic 87k miles
A/C never seems to get cold like it should. Charge is good! (Cool never cold) I get the normal A/C water drip after I shut off the car. So I know something is getting cold.
Saturday, May 29th, 2010 AT 10:37 AM
  • 109,874 POSTS
The only thing I can tell you is it could be the blend air door. It determines if you get AC or heat to the interior. If it is stuck, then it may not seal off the heater the entire way. As a result, warm air is mixing with the AC and the air in the vehicle isn't as cold as it could be.
Tuesday, June 1st, 2010 AT 9:08 AM
