2005 Ford Explorer abs brakes
83,692 MILES • 6 CYL • 4WD • AUTOMATIC
SANDY&TABBY
I just recently changed my brakes and I though that I had to bleed them after I was done replaceing the pads. I am having trouble with my brakes. Now the pedal goes all the way down, but when I pump my brakes they work but not good. I pump my brakes with my car running and the pedal goes all the way down but with the car off it stay up the pedal feels fine.I hear air passing some were but only when you have the car running. Is there a way to bleed them is there a way to bleed them or something that I am not doing right.
Jan 22, 2010 at 3:45 AM
  • 110,246 POSTS
Can you explain what you have done?
Jan 26, 2010 at 2:12 AM
