2005 Ford Explorer 2005 Ford Explorer 4x4
2005 FORD EXPLORER
KADIC
Transmission problem
2005 Ford Explorer 6 cyl Four Wheel Drive Automatic
I attached dry weight 2.500 lbs Travel trailer on my SUV first time last Saturday. By the VIN number towing capacity on my SUV is 3.500 lbs.
Next morning I noticed transmision fluid is leaking.
I am not sure if the towing could cause transimiton leaking? Thank you so much and have a nice day.
Oct 22, 2008 at 12:06 AM
RACEFAN966
  • 5,029 POSTS
NO towing should not cause a trans leak it probable just a freak thing that it happened at the same time. Now where is the leak coming from?
Oct 22, 2008 at 2:44 PM
KADIC
SUV is still in the repair shop and they don't know yet where is the leak coming from.
Oct 22, 2008 at 11:53 PM
RACEFAN966
  • 5,029 POSTS
Is there a chance it could have been overfull at all? If it was then when you towed it heated up the fluid a bit more then it usually did and it leaked out the vent.
Oct 23, 2008 at 2:49 AM
