Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Sputter
2005 Ford Explorer 2005 Ford Explorer
2005 FORD EXPLORER
102,565 MILES • 6 CYL • 4WD • AUTOMATIC
TSHAMALI
MEMBER
1 POST
I have a 2005 Ford Explorer with 102000 miles and it seems to be sputtering or rough while ideling. What could be causing this problem.
Jul 29, 2010 at 2:32 AM
Experienced Mechanic
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 29, 2010 at 5:21 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
