2005 Ford Explorer
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIMPUTNAM
I have a 2005 ford explorer. I noticed recently that it was taking a while for the heat to come on and then I started hearing a flapping noise between the steering wheel and the air controls. This flapping noise would continue until I adjusted the temp. control back towards cold. Sometimes it would be normal as I had the heat on and then I would hear the flapping noise again and the air would be cool. What do you think?
Nov 9, 2008 at 11:45 AM
BMRFIXIT
  • 19,053 POSTS
Noise is Blend door motor no good
have it check it is on the HVAC box
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 10, 2008 at 10:40 PM
