The ABS light and the ADVtrac light stay on. Sometimes the 4X4 light flashes. The message says "check advtrac"
Aug 2, 2010 at 2:33 PM
✓Experienced Mechanic
Hi:
The two systems work together. What I need you to check is to make sure the wiring harness to the actuator on the transfer case is clean tight and not damaged. If it is in good condition, the only thing you can do is have the computer scanned to identify where the problem is coming from.
