2005 Ford Explorer
BLONDGUYGN
Engine Mechanical problem
2005 Ford Explorer V8 Four Wheel Drive Automatic
how do i replace a alternator.
Jul 26, 2008 at 3:34 AM
BMRFIXIT
  • 19,053 POSTS
Removal and Installation ALternator
1.Disconnect the battery. For additional information, refer to BATTERY, MOUNTING AND CABLES . 2.Remove the nuts and the engine cover assembly.
 To install, tighten to 6 Nm (53 lb-in). 3.Rotate the front end accessory drive belt tensioner clockwise and position the front end accessory drive belt aside. 4.Position the protective cover aside and remove the generator B+ terminal nut.
 To install, tighten to 8 Nm (71 lb-in). 5.Disconnect the generator B+ terminal and the electrical connector. 6.Remove the 4 bolts and the generator bracket.
 To install, tighten to 10 Nm (89 lb-in). 7.Loosen the 2 bolts and remove the generator.
 To install, tighten to 25 Nm (18 lb-ft). 8.If necessary, remove the nut and the generator pulley.
 To install, tighten to 109 Nm (80 lb-ft). 9.To install, reverse the removal procedure.
© 2007 Mitchell Repair Information Co., LLC.
Jul 27, 2008 at 1:37 AM
