Got Gas came out and wouldnt start I could jump it by touching the points on the starter with screwdriver that would only let me do that twice then we changed starter that didn't work then we took it to a lock place to have the keys reprogrammed thinking that was it from prior research and that ididn't work either. They did say it is not recognizing the key in the column somewhere beause the keys are just fine the anti theft light blinks rapidly when turning the key over which makes us think it could be the anti theft system, or it could be antenna ring and induction coil or maybe deeper than that is there any way to by-pass this problems if so what are the schematics, or I can try to replace steering column. Please help
Dec 6, 2009 at 7:16 AM
