2004 Ford Explorer Wont Start
JW111867
Electrical problem
2004 Ford Explorer 6 cyl Four Wheel Drive Automatic
Car ran fine when turned off last time would not start back, it will hit one time, then nothing but cranking, engine turns good and normal but wont start, battery load test is good obd scans show no faults with key on.
After waiting about 3 hours tried it again, hit once then nothing but cranking.
Oct 3, 2010 at 4:52 AM
  • 75,988 POSTS
Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 3, 2010 at 4:56 AM
