2004 Ford Explorer wont start
74,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHNYBOY123
car wont start getting fuel but no fire and no signal tothe coil pack or any other sensors
Aug 26, 2008 at 5:04 PM
BLACKOP555
  • 10,386 POSTS
since the injectors are pulsing it sounds like the camshaft sensor is good, but since no fire from the coil.
really sounds like the crankshaft position sensor needs a replacement and relearn.
any check engine lights or codes stored?
Aug 27, 2008 at 1:57 AM
GREENFAMILY
What would you think if the scenario were similar where the explorer 2004 4.0 sohc would crank and pulse the injectors, but i only have spark present on the 4-5-6 side of the coil tower and nothing from the 1-2-3 side of the coil tower?
Feb 2, 2010 at 5:54 AM
BLACKOP555
  • 10,386 POSTS
what kind of setup is your vehicle. coil on plug?
check for voltage to all of the coils.
you can use a t-pin and check the ground side for a pulse signal on that side by using a logic probe on the tpin'
this will tell us if its coil issue, power issue. or icm/computer.
Feb 3, 2010 at 10:05 AM
