2004 Ford Explorer wont start
66,875 MILES • 6 CYL • 2WD • AUTOMATIC
FAQFOO
my 2004 ford explorer wont start. the first time i tried to start it, it turned over for about 3-4 seconds strong but wouldnt fire. ( its always fired right up) i let off the key and tried it again and nothing. ive replaced the battery, the starter ( the solinoid on the starters good as well) and the inline fuse is good. when i turn the key theres no cliicking as the starter is not getting power. all the lights and radio works (BRAND NEW BATTERY). in the fuse box under the hood theres an ignition relay and a starter relay, ive replaced these as well. running a test light, its getting power to the relay recepticals. im installing a new ignition switch but dont think thats the problem as it turned over for 3-4 seconds before. the ignition coil maybe??? ANY advice would be appreciated.
May 10, 2008 at 11:08 AM
BLACKOP555
  • 10,386 POSTS
check to make sure all cables are connected.
next check to see if the starter will turn with a batteyr attached to it, if it will then chances are its the ignition switch if all you listed was good and wires are good.
if it doesnt turn, the starter is bad.
May 10, 2008 at 12:51 PM
