2004 Ford Explorer Windows and radio
2004 FORD EXPLORER
35,300 MILES • V8 • 2WD • AUTOMATIC
TEXASGIRL
My windows and radio are not working! Are these
two things connected somehow??
Jul 28, 2008 at 2:13 AM
MUSTANG87
  • 261 POSTS
possibly you have bad fuses.under dash on fuse box chek all fuses and change any tha r bad burnt.you have the car manual right>it tells u in there witch fuse is for what.also sometimes in back of fuse box cover it tell you to witch fuses r for what power radio windows etc.easy to check.you can do it yourself.might say in letter like this rad for radio or sometimes it just says radio --if fuse is for both it says on cover like radio pwindows etc.just chek m all if any r burnt you can tell right away.good luck.one at a time chek.
Jul 28, 2008 at 5:20 PM
