2004 Ford Explorer vehicle barely runs once engine gets abo
RHAISLIP
Engine Performance problem
2004 Ford Explorer 6 cyl Two Wheel Drive Automatic
The vehicle has 104k miles.It started running a little sluggish so I changed spark plugs. It still ran sluggish and started basically shutting down once you surpass 3000rpms.I've had the coil pack and the catalytic converter checked and both were ok, but the problem still exist. Do you have any suggestions as to what the actual problem may be?
Jul 29, 2010 at 4:18 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 29, 2010 at 4:22 AM
