2004 Ford Explorer TARNSMTION HAS NO DIP STICK
78,000 MILES • 6 CYL • 4WD • AUTOMATIC
GEEZYFRIED
HOW DO I GET MT TRANSMITION FLUSHED WHAT IS THE ESTIMATED COST
Mar 14, 2010 at 10:53 AM
BLACKOP555
  • 10,386 POSTS
you can get it flushed for bout 60 dollars
but i strongly suggest against doing this.
Mar 14, 2010 at 4:25 PM
GEEZYFRIED
why not get it flushed what do u suggest i do
Mar 14, 2010 at 11:27 PM
BLACKOP555
  • 10,386 POSTS
well when they do a flush they dont change the filter. just simply flush it. and well if you ever had a trans apart there is alot of sediment in the bottom of the pan. when they use the machine to fush it it comes dumping in the pan under pressure and can stir up the sediment and then when the vehicle is ran sucks right up into the filter and some bypasses it causing solenoids to stick in the transmission.
my suggestions is drop the pan. clean it out and refil it.
Mar 15, 2010 at 2:18 AM
