2004 Ford Explorer System failure
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAROCKET
I have a 2004 Ford Explorer six cylinder with three system failures that occurred at the same time. One is the fuel gauge, the second is the radio, third the power windows and finally, there is a Check Engine warning indicator that came on. This happened right after I cut the wires to the visor vanity mirror. The visor was broke and kept dropping in front of my face as I was driving. . Granted it was a mistake to cut the wires but I need to know how to fix it. If you have some knowledge of this problem please provide suggestions. All other on board systems are fully functional.
Dec 16, 2009 at 1:48 PM
  • 110,251 POSTS
Are there only 2 wires going to the visor and did you cut them at the same time? If so, you shorted the system. Have you checked fuses?
Dec 23, 2009 at 12:56 AM
