Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Ignition
Spark Plug
Replace/Remove
2004 Ford Explorer spark plugs
2004 FORD EXPLORER
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
COREY77JONES
MEMBER
1 POST
I changed the plugs and wires. I checked the order and its right . Now it runs bad it misses and wont rev over 3000 rpms
Mar 7, 2010 at 5:21 AM
BLACKOP555
Experienced Mechanic
did you do one plug and wire at a time?
are they the proper plugs and proper plug gap.
also did you route them the proper way
Mar 7, 2010 at 8:10 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
