Serpentine Belt Replacement and Diagrams Please
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
GWEYRICH22
How do I loosen the belt tensioner on the serpentine belt. I've loosened the bolt attached to the tensioner pulley but it still won't budge. I tried a rocker arm to spring in loose and it still won't budge?
Feb 14, 2010 at 8:26 AM
  • 110,248 POSTS
IT should pivit. I believe on the explorer, you can place a wrench on the bolt attaching the pulley and pivot it from that point. Here is a picture.
https://images.2carpros.com/forum/automotive_pictures/249084_a_2.jpg
Try that and let me know if it helps. Joe
Feb 14, 2010 at 3:20 PM
F0RDPROBLEMS
Shakes or Wobbles problem
2003 Ford Explorer Four Wheel Drive Automatic 83000 miles
First, my car was in a front end accident about a year ago, and after getting the car repaired, there was a whine. The auto repair shop told me it was related to the serpentine belt and would need to be replaced. The car started to make the noise even louder, so I took it to Midas to replace the Serpentine belt. They said they did, then it broke again, and they said it was one of the pulleys. So they repaired the pulley.
The chirp/whine didn't stop, but it didn't seem to have any effect on the car.
Now, there is shimmying and a really weird repetitive thudding noise. When driving it seems to be on front driver side, when I walked along side the car when someone drove, it seemed like it was coming from the rear. It happens at slow and faster speeds.
I plan on taking it to a shop tomorrow or the day after, but I was wondering if there was any clue as to what it might be or how much it might cost to fix.
Mar 27, 2020 at 5:08 AM (Merged)
REDTOGERCORP
I had the same problem with the wobble and loud rumbling noise in the front end. A few months after it started happening the ABS light would come on. The problem turned out to be the wheel bearing hub assembly.
Hope that helps.
COACHROHO
how do you change a serpentine belt on a ford explorer. how do i take it off and then put it back on
  • 110,248 POSTS
The belt is held in place with an automatic tensionier. What you do is with a wrench, turn the tensionier in the direction to release tension from the belt and slip the belt off.
EMAC08
2001 Ford Explorer 6 cyl Four Wheel Drive Automatic
how to install a new drive belt
Mar 27, 2020 at 5:09 AM (Merged)
RICKMAR
  • 170 POSTS
Depending on the configuration of the Alternator, A/C, Power Steering, Water Pump, Idler and "Tensioner type" you have, one of the two diagrams below shows the belts routing. The "Tensioner" is spring loaded and needs to be pulled back to allow the belt to travel over it. Then slowly release the tensioner onto the belt. The tensioner constantly applies pressure on the belt keeping it tight. DOUBLE CHECK THE BELT ROUTING (#1) OR (#2) BEFORE STARTING THE ENGINE!! #1
https://images.2carpros.com/forum/automotive_pictures/433905_Belt_diagram_40L_1.jpg
To use the "bypass belt routing" you will need a smaller drive belt. #2
https://images.2carpros.com/forum/automotive_pictures/433905_Belt_Diagram_40L_2_1.jpg
Good Luck; Rick
MEYMAW
I was told my serpentine belt was going a week ago. today my car wouldnt start! The AAA guy said it could be my alternator and belt. Are they together? Do they do the same thing? What do you think, how much am I looking at in price?
RICKMAR
  • 170 POSTS
The serpentine belt and alternator "are" related but does not mean both need replacement.
You were told your serpentine belt was going a week ago. How that is know is with inspection. Look at your serpentine belt has cracks or cuts or nicks etc. Usually the rubber gets old and starts to crack. I would say your belt has "visible" cracks . The cracks weaken the belt and it then starts to stretch. Usually when stretching starts the alternator is less capable of putting out it's full charge. Now add in your lights,radio,heater etc. The alternator is having one hell of a time trying to power up everything and not let the battery into the picture. Now the battery is not being charged by the alternator the way it should be. And then everything hits the fan and............... your battery is dead.
*1 The guy from AAA probably saw the belt was bad and stretched causing bad output of the alternator.
*2 The alternator is no longer functioning properly (Low or weak output) - 90% of the time the alternator is fine.
*3 To absolutely know if it "is" the belt do this:
Engine OFF - look at the belt going around you alternator pulley. About 3 - 4 inches away from the pulley push down on the belt with your finger. The belt should flex/move very little only about 3/4 inch full flex/movement. If the belt seems very spongy, soft and weak... a bad belt is starting to play a "BIG" roll in the problem. If you push down on the belt and there is a very large flex/movement like you are pushing on "clothes line rope"...you "should" find your alternator is "fine" and you just need a new serpentine belt.
If the belt looks good, has very little flex etc. I would start thinking the alternator just might be no good. - I am almost sure ...80% sure you will find the problem with a dead battery was caused by a bad belt.
The alternator needs the correct amount of tension applied to it so it will operate as it should.
I do not know what engine you have, I can just say on that ....a serpentine belt for a 5.0L 8 cyl. is around $50.00. You will also need to pay labor if you are not doing the work so.....Somewhere around $80- $85 for the belt and labor.
If it is the alternator... I do not know what your present amperage output is. The higher the output the higher the cost average price is $131 for the alternator plus labor for removal and installation.
You can check the price for the alternator out here at this link:
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1354542&parttype=2412&a=FRc1354542k487570
A good place and good prices.
Again, I would bet your just about say for sure you serpentine belt is the whole problem....around $80.00 or less ...(Belt & Labor).
** Tip, if you have a Advance Auto Parts near you they will check your alternator (Free of Charge)**
I hope that information helped. If you need any more help just send me a private message and I will get right back to you.
Good Luck;
Rick
LOKREBS
Electrical problem
1998 Ford Explorer V6 Two Wheel Drive Automatic 110000 miles
I need to install a new fan belt, but the place where it needs to go is not accessible . The shroud and other components are in the way. Can you provide step by step instructions on how to do the installation? What must be removed and in what order to replace the belt? Thank you.
FLEXY5
  • 512 POSTS
the repair can actually be made fairly easily. the only part (other than the belt) that needs to be removed is the intake tube. The passenger side of the engine compartment has a box that houses the air filter. Simply unclip the upper part of the box, unplug the MAF and loosen the clamp on the other end of the intake tube. you should then be able to easily see the belt tensioner. the belt should feed under the water pump pulley and you should not need to route it around the fan blades to get it out. But if you need to just manuever it tbetween the blades and the shroud. You do not have to remove the shroud, as this requires removing the fan blades.
Mar 27, 2020 at 5:10 AM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
How do I replace the drive belt I have the5.0v8
JDL
  • 16,098 POSTS
Remove the air cleaner outlet tube. Use the drive belt tensioner pulley bolt and rotate clockwise, Use a wrench or socket. Once you have slack in the belt, remove belt.
TOBIACLAN
I have changed my water pump on my Explorer. When I installed the serpentine belt and started the engine, I had a loud squeal. I shut off the engine and noticed that my tension pulley had pulled completely through and wasn't applying any pressure on my serpentine belt. I replaced the belt thinking that the belt had stretched and the new belt had the same result. I have rechecked my belt routing and I followed the diagram in the truck. I started adjusting the tension pulley and noticed that when moving the pulley counter clockwise, that there is a spot that the pulley will stay in this location all by itself. If I continue the counter clockwise motion, the spring does appear to grab and does provide tension on the belt. I don't have a problem changing the tension pulley if that is the problem. But, I can't understand why changing the tensioner pulley would do, since the pulley is a mechanical link and the pulley seems to be pulling through the belt to where the tension is released off of the belt. Is there something I am missing?
SERVICE WRITER
  • 9,123 POSTS
Replace the tensioner assy. not just the pulley. It is used to moving about in a certain range and was probably ready to be replaced anyways. Changing the position a little while doing the pump job just flushed the problem out. Not abnormal to see this happen anytime the tensioner has been moved.
XLT
Serpentine belt
My serpentine belt pop off so I replaced it with one from autozone. I started up and got a loud squealing noise. So I replaced the top idler pulley it still squealed. Then I replaced the belt tensioner thinking it was worn and was not putting engouh tension on the belt but it still is squeaking I checked and rechecked belt to make sure it was on correct. but still a loud noise
BMRFIXIT
  • 19,053 POSTS
Did you recheck the belt route ?
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic_29.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_12.jpg
TGRIFFITH
Thanks so much for posting the diagram!
The bearings went bad in my idler pulley, which resulted in it falling off, and the belt coming off.
Bought the new idler pulley for $15, and put the belt back on according to your diagram, and everythings back in order.
Thanks again!
GINGER22
Engine Mechanical problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic 117k miles
Please help! I replaced my serpentine belt twice & both times it was chewed up & literally shreded. I purchased another belt, this time trying to bypass the a/c compressor (thinking the clutch assem. was the culprit), but to no avail... It is still making lots of noise, not just squealing....I've read to replace the belt tensioner pulley, but don't know. The power steering pump was leaking & it seems that it doesn't spin as easily as the other pulleys. I don't have the money to replace parts one by one - is there any way of knowing if it definitely is the tensioner or others? Thanks!
  • 110,248 POSTS
When you bypassed the AC, did you get the correct belt and route it correctly? Also, when the belt is on, is it tight? Finally, are all of the pulleys lined up straight?
ZEBRA13
I don't know how many belts are on this vehicle.My daughter is stuck uo at college at a gas stationwaiting for AAA .I would like a diagram of the belt system .Is it only neopreme?Thankyou for your help.George
OBXAUTOMEDIC
  • 3,711 POSTS
The is only one Belt (Surpentine Belt) and there should be a belt routing diagram in the engine compartment. It is usaully on the fan shroud.
But here it is....
https://www.2carpros.com/diagrams
