how dou remove rotors they seem to be stuck after brakes are removed should i tapon rear
Aug 27, 2009 at 3:32 AM
BLUELIGHTNIN6
✓Experienced Mechanic
bang on them some with a rubber headed mallet. the brake heat causes the rotor to stick. if it is the rear rotors, ensure your parking brake pads and linings are loosened so it is not holding on the rotor still.
