2004 Ford Explorer Rear Sensor
49,500 MILES • 6 CYL • 4WD • AUTOMATIC
HERNAN29
have an 04 Ford Explorer and the rear sensors just stopped working one day...it has a light by the steering wheel that says it's OFF I turned it back ON however it goes back to OFF every time i shift gears to reverse. What do you think is going on and how do I fix it?
Note: It does work if the car is off but the engine switch is on...
Apr 28, 2008 at 1:55 PM
PAT2257
Most likely, one of you sensors on the rear bumper has gone bad. I think you can check them by using an Ohm meter, but I'm not sure what to look for.
May 23, 2008 at 5:22 AM
