2004 Ford Explorer Problem installing new brake pads
63,000 MILES • 6 CYL • 4WD • AUTOMATIC
AMOOSH322
I'm putting new brake pads on our truck, after I finished and was going to test drive I heard a loud grinding noise only when backing up and braking. Any ideas what this is? When going forward and braking the noise doesnt happen
Nov 15, 2009 at 5:44 AM
  • 110,251 POSTS
Check the backing plate behind the rotor. Many times they get bent or rust causes them to rub against the rotor.
Let me know if this helps.
Nov 17, 2009 at 7:23 AM
