Noises problem
2004 Ford Explorer 6 cyl Four Wheel Drive Automatic <66000miles
When my vehicle was started this morning it started making a loud thumping noise. My husband checked all engine areas he could think of. When the heat is turned on, it gets louder & quicker, same when the turn signal comes on. I turned the engine off & then turned they key to where only the electrical systems came on & the thumping started again. Any help would be greatly appreciated.
08Apr09 update - Thumping stays on when fan is off, but will stop when the temp control is turned to cold. When fan is turned on at cold temp setting, no thumping. No heat output.
Apr 6, 2009 at 4:33 AM
