2004 Ford Explorer lost pressure
SHAHIN606
Engine Mechanical problem
2004 Ford Explorer 6 cyl Two Wheel Drive Automatic
My head gasket burned and water got inside the engine. We change the head gasket and now it doesn't want to start. I did not change the knock sensor. I took it to the mechanic and they couldn't tell me exactly what was wrong the only answer was. "it needs a new engine and still could be something wrong". Any tips?
Apr 11, 2010 at 11:30 AM
  • 75,988 POSTS
Did you make sure the valve timing is correct when you put everything back together
Apr 11, 2010 at 9:48 PM
