2004 Ford Explorer Location of coolant level sensor
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOHNSONDK
I have an engine coolant error code. I have checked the coolant level and replaced the coolant sensor but the code returns within a day of disconnecting the battery to reset the codes. I was wondering where the sensor is that indicates the coolant level and also how to check the sensors with a meter. Am I looking for a short across the contacts or a certain amount of resistance?
Sep 18, 2010 at 3:42 AM
MERLIN2021
  • 17,250 POSTS
To better assist you, the actual code(s) will help. Not showing a level sensor, just ECT(engine coolant temp sensor).
Sep 18, 2010 at 3:47 AM
