2004 Ford Explorer installing new struts
94,000 MILES • 6 CYL • 4WD • AUTOMATIC
STUPIDNAME53
How hard is it for me to replace struts myself?
Feb 20, 2009 at 12:33 PM
BLACKOP555
  • 10,386 POSTS
it is a pretty simple thing to do if you are buying replacmeent struts and are just putting the new ones on, it may be a bit harder if you have to tear down the struts and replace the parts yourself.
Feb 22, 2009 at 8:16 AM
STUPIDNAME53
Thanks for the response!
I got er done, the hardest part was the coil spring change over.
I had to use two sets of spring compressors and a large bench vise.
I was quoted $525 for two struts installed.
I bought the struts for $140 and it took about 3-1/2 hours.
Mar 5, 2009 at 1:17 PM
BLACKOP555
  • 10,386 POSTS
its definetely worth the time to do it yourself. plus now you got good knowledge! be easier if you just bought the new struts. maybe a little more expensive but not much at all!
Mar 5, 2009 at 1:20 PM
STUPIDNAME53
I wasn't able to find new struts with the coil spring attached, but if you can find them as a complete package it would definetly be worth the extra cost.
Mar 6, 2009 at 12:50 PM
BLACKOP555
  • 10,386 POSTS
yes, the dealer might sell them but then theres the markup price. for future refrence you can take in the parts to a dealership or independent mechanic and see if they will put the coils on the struts for you.
Mar 6, 2009 at 2:58 PM
