Engine overheating
39,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLONDIE24
This vehicle began overheating when the AC is on after about 30 minutes....the overheating has literally blown the cap on the radiator and spewed coolant everywhere twice. Ford thought it was the thermostat and replaced it 4 times, thought it might be a faulty switch giving a wrong reading but obviously not since when it reads in the red it does blow...we had the water pump replaced thinking it was that but $500 later same problem. We noticed it overheats too when their is "stress" on the engine, like going up long hills or inclines (we live in Colorado)...so the engine overheats with AC and stress on the engine...any thoughts? It has low mileage, nice car but the threat of overheating takes the fun out of driving it....it seems to be impossible to fix this...Thanks!
Nov 22, 2008 at 5:46 AM
DAVE H
  • 13,383 POSTS
take your vehicle to have the cylinders compression tested .. i think your head gasket may have blown ...
Nov 22, 2008 at 6:18 AM
BLONDIE24
Thanks Dave...is that an expensive repair?
Nov 22, 2008 at 9:58 AM
DAVE H
  • 13,383 POSTS
compression test .. will take about an hours labor charge ?? cylinder head gsaket replacement will cost $500 for one cylinder head .. you have 2 on your vehicle .. but usually only the one has blown ??
Nov 22, 2008 at 10:54 AM
