2004 Ford Explorer Idol & power problem
113,000 MILES • 6 CYL • 4WD • AUTOMATIC
JETZWILER
Our Ford Explorer acts as if its not getting enough power to the tranny & car functions to work. It has a new heavy duty battery, brand new alternator and a total electrical system check. I was told to have a sensor checked, but don't know what sensor would cause all this. Its to be a sensor on the firewall, so any info to this problem would be greatly appreciated. I was told it regulates power to tranny & fuel emissions. Help!
Jan 22, 2010 at 8:44 AM
  • 110,251 POSTS
Has the check engine light come on? Can you describe what the vehicle does? As far as sensors, if you have a bad one, it will most likely set the check engine light.
Jan 26, 2010 at 1:45 AM
