2004 Ford Explorer fuel fill problem
90,000 MILES • 6 CYL • AWD • AUTOMATIC
ALAN4977
when putting fuel in tank, the pump nozzle shuts off as if full and gas backs up out of neck. I can only "trickle"fuel in. whats broken?
Dec 18, 2009 at 4:25 AM
  • 110,248 POSTS
Here is what I think is the problem. First, the place you fill the tank from is called the filler tube. If you look under the car at it, you will see a smaller tube running along side of it. That is the breather tube. IT allows air to exit the tank as it fills with gas. If it is damaged or blocked, there is no where for the air to go which results in fuel not being able to enter the tank and the fuel filling the filler tube and coming back to the pump and shutting it off.
Check it for damage and let me know what you find. Thanks for using 2carpros.com.
Dec 18, 2009 at 4:27 PM
