2004 Ford Explorer ENGINE WILL CRANK BUT WONT START
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
JASONG40
THE SERVICE ENGINE LIGHT IS ON AND THE WRENCH SYMBOL IS LIT ON THE DASH. THE CAR RAN HOT A COUPLE OF DAYS AGO AND IT DID SPRAY FREON ALL OVER THE ENGINE. THE SERVICE ENGINE LIGHT CAME ON AFTER WE CHANGED OUT A HOUSING AND GASKET. THE CAR WONT START BUT WILL CRANK. A FRIEND OF MINE CHANGED OUT THE IGNITION COIL. AND RESEST THE FUEL PUMP INSIDE THE CAR NEAR PASSENGER. WHAT WOULD CAUSE THIS PROBLEM. WE CHECKED FUSES AND THEY ARE GOOD. THE SPARK PLUGS DONT SEEM TO BE GETTING ANY FIRE.
Mar 15, 2010 at 2:19 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 15, 2010 at 2:51 PM
