2004 Ford Explorer Droning noise at speeds above 40 MPH
PHAKER
  • 2004 FORD EXPLORER
  • 6 CYL
  • 75,500 MILES
I hear a droning noise starting at about 40 mph that starts as a medium-tone drone and then rises in pitch and loudness as I speed up, though it seems to go away as I get up to 80 mph. It is not accompanied by any shakes or shimmies. The tires have been checked, re-balanced, rotated, and the front two replaced; the back two only have 2000 miles on them. No tire configuration changes the sound. The car handles like there's no alignment problem, and as best I can tell the bearings make no noise when rotated by hand. Also this may be totally unrelated, but the ABS light sometimes comes on, though it usually does not come on if the engine is hot from a previous running. Thoughts?
Thursday, October 8th, 2009 AT 2:53 PM
LANDIS STEWART
Iv got a 97 thats doing the same thing. I took it into an off road center and they gave me a 1000$ list of problems. Lower ball joints, tire rods, stabillizer links, wheel bearings, sway bar, CV joint, and the alignment. (Yes its a wreck right now) The inside of my front left tire is almost bald and I think thats whats making the droning sound. You might check both sides of your tread.
Friday, October 16th, 2009 AT 12:44 PM
P RINDGE
  • 9 POSTS
Check to see if you have posi-traction rear end. My 2003 Explorer V8 2 wheel drive 3.73 posi does the same thing. You can make the noise change by releasing the gas pedal a little then pressing it again.
I have 53,000 miles with original tires (good wear) and brakes (just about ready for a change). No change after interval tire rotation. My 88 tbird posi rear end does the same thing so I'm not concerned.
Phil
Thursday, November 5th, 2009 AT 12:52 PM
