I jaust had the same problem where the ABS light is on & the 4x4 flashes intermittently.
I had the rear ABS sensor replaced and that fixed all the problems you mentioned. There is only one for the rear
You also have two ABS sensors on each front wheel they are on the inside of the rotor. You have to remove the rotor to remove the sensor. They come with a wire and cost about $130.00 each. Good luck.
SPONSORED LINKS
Tuesday, August 12th, 2008 AT 6:48 PM
