Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Brakes
Symptoms
Stuck On
2004 Ford Explorer Brakes Lights
2004 FORD EXPLORER
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
DEANDREA
MEMBER
1 POST
My brake lights will not go off they stay on all the time, what should i do?
Feb 7, 2010 at 2:53 AM
Experienced Mechanic
Have you checked the brake light switch on the top of the brake pedal? Make sure it isn't stuck and is properly adjusted.
Let me know what you find.
Feb 11, 2010 at 7:10 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
