2004 Ford Explorer brake lights stuck on
2004 FORD EXPLORER
BARBADOS
Electrical problem
2004 Ford Explorer 6 cyl Two Wheel Drive Automatic
brake lights (not tail lights) are stuck on. had to disconnect the battery for the night. checked all the wiring and fluid level and everything obvious. mileage is about 38,000
Sep 26, 2008 at 3:32 PM
Follow the brake pedal arm till you run right into the brake switch-now either you adjust or replace the switch.
Sep 26, 2008 at 10:07 PM
