2004 Ford Explorer 4 wheel drive
MRSFLES1206
Engine Mechanical problem
2004 Ford Explorer Four Wheel Drive Automatic
My car seems to have locked itself in 4 high this morning when I left and now the ABS light is on and the 4 high light is flashing any ideas what this could be?
Nov 8, 2009 at 11:05 PM
  • 110,248 POSTS
I need you to check something. Have a helper turn the 4wd switch while you check for power to the 4wd actuator on the transfer case. IF there is power, chances are the actuator is bad.
Nov 10, 2009 at 12:58 PM
